check engine
  1. Z
    Check Gauges light going on & off
    Hi, Checking to see if anyone has had a similar issue as I am having. I have an '05 with the 4.7. The "Check Gauges" light goes on and off many times while driving, and while the light comes on, the oil pressure gauge drops, but most of the time by the time the gauge gets all the way down, the...
  2. F
    22’ Laramie battery drain issue… any help appreciated.
    I have a Laramie that’s not even a year old and since last week, car randomly stopped turning on due to a battery issue. Whenever I hook up the battery to a quick charge it starts right up. In addition, I have a ton of lights on including check engine, washer fluid low, abs, shifter malfunction...
  3. B
    Fuel Sensor Fail... should I fix it?
    I have a 2014 Ram 1500 with just under 60k miles on it. A couple weeks ago the check engine light came on, followed by a Fuel Sensor Fail warning. Took it into the shop today and they quoted me $1,200 to replace the fuel pump. I've read other threads on here where guys just fill up their tank...
  4. S
    2011 ram 1500 frequent codes
    Hello, I just recent purchased a used 2011 ram 1500 from a dealership. For about the first 2-3 weeks I owned it I had no problems and it was running great. Since this I have thrown multiple codes. Currently, about once a week, I am having to replace a new sensor. The first was a P0457. This was...
  5. D
    Engine check light - Code P0299
    Driving my new 2020 Ram 2500 CTD (just under 2k miles), the orange "engine check indicator" lit up with an audible ding. This was about 5 miles down the freeway after leaving the wash-it-yourself carwash which involves use of a pressure sprayer. Driving was unaffected. Light stayed on for...
  6. K
    P0420 code problem
    I've got an 07 1500 5.7 QC 4x4. She's got roughly 181k miles on her. For about a year now I've had an intermittent cel for P0420. I've done a spark plug change, ran system cleaner, reset ecm, used an infrared thermometer and live data feed to try to diagnose it. Both infared and the LD...
KAKA
