MikeinJaxHemi
- Sep 30, 2018
- 31
- 8
- Location
- Jacksonville FL
- 2014
- 5.7 Hemi
I was getting a new key fob programmed at a dealership and they said I have a code p1009 that they found. A code that doesn't turn on the check engine light apparently. The indicated I needed a new humidity sensor and that it would be about $130. I said I will look into it. So, it appears my AC is working fine and haven't had any issues. From what I understand that is on the windshield. How do I remove the plastic cover without breaking anything. I can get the part for fairly cheap. Not sure how I can check that code after I replace it or should I just not replace since everything is cooling just fine. I can put it on manual climate and turn recirculate on and off just fine, AC is cooking fine. Not sure why I need to fix it. Anyone want to chime in on this?
