P2509 SRS light no other warning lights
saboken
2012 RAM 2500 Cummins Airbag light came on today, no check engine light. I pulled the codes it's P2509 permanent. I checked all the fuses, disconnected the batteries. The code is still there I can't erase it with my scanner . The batteries seem ok I just replaced them about 7 months ago with 2 new AGM intestates from Costco. I am in Quartzite AZ camping lots of dust . I'm not sure if the dust could have gotten into something? The truck drives fine. But I need to figure this out before I leave breaking down with a Fifth wheel camper in the desert is not fun. Any idea what to check that I didn't yet?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Parking out there on Hwy 95?
Quartzite's Main Street is definitely a dust bowl
I was Quartzite 2 years ago, 2 trips a week for 6 weeks
we were hauling Jail Cells to San Diego :)
2011 - 2015 Cummins 6.7 trouble codes list shows
P-2509-ECM/PCM Power Input Signal Intermittent
If you're using an OBD-II scanner to find out why your check engine light is on, a P2509 code means that your engine's electric signal to the ECM is intermittent rather than constant. As a result, the ECM is not getting the steady power supply from the battery it needs to function properly.
How do I fix code P2509?
What repairs can fix the P2509 code?
  1. Repair or replace blown fuse.
  2. Repair or replace faulty fusible link.
  3. Repair or replace faulty circuits.
  4. Repair or replace faulty battery.
  5. Repair or replace faulty battery cables.
  6. Repair or replace faulty PCM relay.
  7. Replace and reprogram PCM.
For most Cummins owners, P2509 is an issue with the driver-side battery.
