Pacesetter install
truckin151
2013 sport
My O2 is on the driverside right after the rear O2 sensor after the cat. Havent ran into any issues in that location and like kens, mine has been real close to what the dyno sniffer showed
ST-8
ST-8
What kind of clamps did you all use from header to y pipe?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The 3" band clamps I posted above is what I used. Make sure you slide it as far as its gonna go and clamp it.
ST-8
ST-8
KGB did you get your from a parts store or online?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Local speed shop for one of my setups then when I checked with my local general parts store when I changed it again and got them through them. Make sure they are stainless steel so they can form to the pipe when you bolt them down. Get them tight and start the truck and let the pipes warm up and retighten. The headers you got look coated which will still be cool but the clamp on the ORY pipe will be hot as hell so have the clamps in a spot you can access. Give that PN I listed above to your local parts stores and see where it gets you.
Blackram
I never had much luck with those band clamps. They always leaked even if it was only a little bit. Eventually I just welded it all together.
ST-8
ST-8
Thanks for the help guys. Gonna go to the parts store tomorrow an try getting some clamps along with tranny fluid
truckin151
2013 sport
I just used the clamps that came with the ORY kit. Never had any issues with them on the header collector.
TylerB
FL
I'll be welding the majority of the ORY for Mario. We both just wanted something that was easy to remove in one piece. We'll only use the supllied clamps where necessary and I'll notch the ends of the pipe to let them bite down better.
truckin151
2013 sport
That's how mine are at the header collectors, we made a small cut down the center of the pipe for easier removal and tighter seal.
TylerB
FL
******* rain
ATXHEMI
Round Rock Tx
Hope y'all aren't getting what we got Wednesday night. I got 7.5 inches over night. Some areas got 15+ inches over night. The flooding terrible. And it's supposed to rain again Monday. We needed the rain but not all at once.
TylerB
FL
Not that bad. Just enough scattered to keep the ground damp and be annoying.
ST-8
ST-8
Well finally got around to getting these on. Too dark too get pics once we finished.
I REALLY need upper ball joints
ST-8
ST-8
Oh yea this too :)
TylerB
FL
Yea! I wanna see some pics and videos.
Saleen5150
