Painting mounted wheels
Spoonsize
Myrtle Beach, SC
Think this might work? Tape off the rim and most of the steel wheel. Plastidip the tire outside the rim. Remove the tape from the wheel and tape the outside of the tire/panels etc. Paint the rims. Then peel the plastidip off the tires. Your thoughts??
Pull Ya
Cedar Creek, Tx
Just cause I hate to mask stuff off----I would just dis-mount the tires
Jay
0rion
Ohio
5.9 cummins
Let air out so you can push in on bead and slip playing cards between tire and rim. I have a deck of cards here that have that as their sole purpose.
Edit: nevermind...see how you're plastidipping them. I was thinking rattle can.
WTM75
Upstate NY
3.6 Pentastar
They actually make stuff for doing what you are talking about. I don’t remember what it is called, but sign painters use it. My buddy who does custom painting uses it for doing graphics. Paint it on with a brush and then he just cuts out the graphics. It is translucent.
McBroom
Denison Tx
Hemi 6.4L
If I were gonna do this.
I would get a pack of 3x5 index cards and tuck them in between the wheel and tire. Overlap them till ya have a full ring. Paint away!!
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Tradesman Power Wagon
MarshRam
2014 SLT 4x4, 2012 ST
^^^^ just cover the tire in plastic, doesn't need to be perfect near the lip and use the index cards. I did some plastidip on my rims with the index cards only and didn't get any over spray. If I were to paint them, I'd probably wrap the tire in plastic for safe measure and then line the lip of the rim with index cards
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
It peels/rubs off the tire, wouldn’t worry about masking anything but the rotor/caliper behind it.
grynfischer
Stockton, CA
V8
You could've remove the tires first but since it works for you, I guess it's alright.
Jhuss96
Northeast US
Plastidip the overspray is no big deal. I dipped the emblems on my last truck, while you obviously want to avoid overspray whenever possible it comes off pretty easy. Just want to be sure it's masked off enough so that pulling on the overspray plastidip won't mess with the finish of the wheel.
