Parking brake & Traction Lights On...
Rw1984
Greeneville, TN
2011 Ram 150 4.7 88k
Would a wheel sensor cause both Park Brake & traction lights to come at the same time when I start the truck up? They stay on now but I do still have cruise control.
Tach_tech
5.7L HEMI
Get the codes retrieved. ESP and park brake lights can come on for a lot of different reasons.
Tach_tech
5.7L HEMI
You need a scanner that can retrieve ABS codes. Most cheap code readers/scanners can only retrieve powertrain codes. If the lights are on there will be codes set, you just need a proper scan tool to retrieve them.
Doodoo972
Martinique
Yes AlfaOBD definitively give the ABS code. I use it a couple of days for ABS light + traction lignt. For me it was the left rear wheel sensor.
Jeepwalker
WI
2012 Reg Cab, 4x4
Very well could be a faulty brake switch (if you haven't fixed it yet). Had the same thing on my 2O12 and that resolved it.
