jayf
Just bought a 2022 tradesman. I'm regretting buying this already for multiple issues with a dishonest previous owner. The mirror was broken when I looked at it, but he said he was going to have a garage replace it and it was replaced when I actually picked it up. (Unfortunately, I already bought it). The power mirror does not work. I took the door panel off and saw that it WAS plugged into the door module. There are several labeled plugs on the module. It was plugged into "B" and after removing the plug, I noticed that someone had shaved off the connector so it would fit in the slot it was obviously not meant for. So it's likely the POS previous owner did a DIY special in stead of using a qualified mechanic.
I'm pretty sure I can move the pins around and put the connector in the correct part of the module if I have the wiring information. The mirrors are not the power retractin or folding, but they are heated and have the adjustments for the glass. Does anyone have the information for this so I can get the mirrors functioning again.
Can anyone provide this information for me? Thanks in advance.
