@kurek - isn't this just the manual top gear selection switch? Used to be the console shift lever tapped left and right, then they got rid of that and used a steering column lever with switch on the lever handle, now I don't know what they've done with the dash-mounted knob.
The buttons are on the steering wheel and they work wayyyyyyy better than the RFE transmissions@kurek - isn't this just the manual top gear selection switch? Used to be the console shift lever tapped left and right, then they got rid of that and used a steering column lever with switch on the lever handle, now I don't know what they've done with the dash-mounted knob.
I have the original 66RFE Chrysler Trans 6 speed. When towing I use tow mode switch for higher rpm shifting and gear selector switch limit in 5th gear so it doesn't over-torque the trans kicking out of 6th gear after going downhill or on flat road.
I believe this was introduced by Audi and called "Tiptronic" back in the day. It's nothing more than manual shifting of an automatic transmission.
Which one would you recommend?Are you talking about an after market throttle controller or the manual gear selector switch?
The gear selector switch won't give you any more power. It'll only adjust down what your top gear is. ie 6th or 7th gear instead of 8th. And if that's what you're thinking about, 6th gear is your 1:1 gear. 7th and 8th are overdrive.
The aftermarket throttle controller is called a Pedal Commander. There are also other brands for less money that do the same thing. They have a passing feature that you can adjust.
you can manually upshift from 1 to 8 at full throttle and downshift at speed and it will rev match and seamlessly knock out every gear down to 1. with a good exhaust it crackles like an srt while downshifting and engine braking with full torque converter lock up in every gear! amazing technology I say! I spend more time in manual mode than not, its that good!
oh Im quite aware of the limitations like I said I use it daily. say you are accelerating full throttle in a lower gear like 3 or 4 and you are at 5500 rpm when you press gear+ it will immediately shift to the next gear, but like you said only because the conditions are right for the computer to immediately ok the shift.You can't actually "manually upshift". It's just a range limiter, the transmission still decides when to upshift and downshift within the X gears you give it; so if you +/- to 5, the transmissions decides what gear to upshift and downshift into, any gear between 1 to 5.
So if you're driving lazily and "upshifting" way too early, the computer is going to ignore that until it knows it can actually do the upshift.
If you're driving WOT and hang onto the gear way into redline, then it may appear that your next upshift is actually a real upshift, but the computer is finally allowed to upshift at that point so it does it. But if you then again really fast upshift 2 more times, the transmission ignores that until it needs the next shift.
I don't have one. I will say do your homework. Some of the very cheap ones can cause problems but there are good ones cheaper then Pedal Commander. Do a search in here and you'll find plenty of information on them.Which one would you recommend?
I'll buy it for my Durango first see if I like it. Never ran and pedal thingBanks Pedal Monster. It's the only one that is powered by a stable power source (obd2 port instead of the line voltage on the pedal sensor) and the only one that has not (yet?) caused any unintendend acceleration and/or dead pedal and/or christmas lights on the dash.
