Bcryan
My gripe about the throttle response is at take off.PC doesn’t really change it much IMO.. Now mid acceleration you definitely notice it and I don’t have to paddle shift it to keep the RPM up
Bizarre. I am a fairly performance oriented driver and never felt the least bit disappointed when I stab the pedal.
All, those who have installed in the 5th Gens, any issues with the Christmas tree in the dash going haywire? Have seen some reviews that eluded to issues with throwing codes and lights up the dash. Been thinking about it but concerned about codes.
Purchased a PC78, should be here tomorrow, 14 August. Where have you all ran the cables that go to the pedal hook up? Noticed that there is no open space under the steering wheel like my 4th Gen. Seems that Ram decided to close up the entire area around the steering wheel with plether.
Thanks, will give that a shot depending on the length of the PC cable.I stuck mine down behind the center console on the flat surface in between the console and the heater ducts.
Installed today, throttle response is spot on. BTW, did you download and using the APP for the PC for BT? Looked on the APP store, bad reviews on the APP itself. TIAI’m sure most have heard about it or have it. But I just got it and damn. I actually have throttle response. A very welcomed and needed modification to the lazy factory setting. That’s it. JB
Whoever said there was no difference probably had it set in Eco, or maybe City, but in the negative range. Nobody ever said it didn't do anything while set in Sport+ 4.Also, there are some that have mentioned the PC makes no change from take off. I totally disagree. The hesitation is gone and the truck no longer feels like it's falling on its face.
It's my daily driver so I settled in on City +2 for now. But Sport + is just crazy.
Anybody using this with an eTorque? PC78 Bluetooth? The PC website does not list the eTorque.
So, I have a couple of questions about this Pedal Commander.
1) Does it affect the PCm at all. Say I use it for 3 months and it lost it's novelty, does it affect the PCM at all afterwards?
2) Does it "actually" make the truck faster or just make it feel faster? Any proof it makes the truck faster, if that is the case?
