Pentastar + Pedal Commander
BCinNC
Raleigh, NC
Hi all.
There's not a ton out there for the Pedal Commander for the V6. I wanted to put something out there for anyone doing research.
I'm not interested in doing extensive mods to the truck and can't see myself ever going through the time and expense to do chipping, so that left Pedal Commander.
Stock: I didn't like the stock acceleration, especially the dead spot in the middle of the pedal travel that seems to do nothing. I didn't like that I nearly had to floor it to get the transmission to kick down.
Short answer: It changed how the truck drove and responded to acceleration.
How it drives now: The acceleration is more aggressive and predictable.
Due to the throttle position tweaks (I assume) I have also found the shift points to be slightly more aggressive. To explain, in stock form, under moderate acceleration, I found that the transmission would shift a little early - especially into third gear - usually at or a little before 2k RPM. The overall effect was a sluggish driving experience. After Pedal Commander it holds onto the gear slightly longer - 2.25-2.5k RPMs - which makes for a more consistent linear acceleration.
What I tested:
City:
Very noticeably improved acceleration. Easy to modulate speed to take off hard or a more casual or 'poky' take off from a stop.
Sport: a bit more 'jumpier' off the stop. This is your choice if you have to be the first off the line at the traffic light.
Sport +: Snapping necks :) I was literally scaring people in parking lots because it was so twitchy.
Eco: It's slooooowwww. Note, I did see that someone on a forum (here or otherwise, I can't remember) that said it *** dangerous. That's ridiculous, step on it and it moves. It's the first 1/3-1/2 that's slowed down.
Numbers: I measured MPG, too, because I was curious what impact each mode had. I stuck with one mode for a complete tank.
Start MPG with stock throttle - average of 7 fill ups: 19.45 mpg
City - 19.4 - essentially no change
Sport - 21.34 - 9.6% increase - would need to repeat this to feel comfortable saying sport improves mpg.
Econ - 20.76 - 6.7% increase - lots of hwy with this tank. That's what I attribute to the increase.
I'm running city +4 right now. I might bump up to sport after a few tanks.
Quyonmob
Canada
Great info. Might pull the trigger on one myself.
Pull Ya
Cedar Creek, Tx
^^^ Please give us your impressions after you have them both installed
Jay
That_CAT_Guy
Southampton County, VA
I got one in my truck and love it, woke it right up. I usually keep mine sport +1 and I average around 20-21mpg, but have seen up to 27 on the highway.
Wondering how the truck will act with the PC when I install the ripp coil packs and do some exhaust work :banana-mario:
rule18
Admin
NY
2017 Rebel
I've been running a PC in my 3.6, set at Sport 3 for 2 years and have nothing but positive experiences.
RLJ10X
Southern Indiana
If my truck was ever stolen, and never recovered, it would be a tough engine choice for me. The Pentastar is that good. (I have one in my Wrangler)
rule18
Admin
NY
2017 Rebel
But I'm giddy on my drive to work and back at Sport +2. It's just such effortless thrust and it's so smooth. The Pentastar really is a serious engine.
When I ordered my truck, I went back and forth between the 3.6 and the 5.7. At that point, the 3.6 was $1500 less expensive and I'd had good experiences with my Wrangler's 3.6 so that's what I went with. Haven't regretted it yet, including towing from time to time. The extra bit of payload capacity was a nice bonus too. The PC upped the fun factor for sure...
That_CAT_Guy
Dammit. I looked those up so now I have to get them, too.
The plans to get them put on around the same time I do my bilsteins
RLJ10X
Southern Indiana
There was a guy on this forum, about 8 months ago that had a Pentastar, 8 speed, 2WD RCSB. He put 4.10s in it, then immediately sold it. I was dying to hear more about that truck.
Have any of you V6ers put a CAI on your truck? Thoughts?
joshhhh
