https://youtu.be/liM9AeNrwiQ
Ok, I installed the K&N 77-1564KS Performance Intake Kit for my 3.6L Pentastar yesterday and I love it. It took a little under an hour to install and the truck sounds much more aggressive under acceleration and the throttle response is improved as well.
The best way to describe the sound difference is it goes from a low "growl" to a loud "howl" when moving through the RPM range at wide-open-throttle. When maintaining speed it's just as quiet as it was with the stock air box. Keep in mind that I have a 2014 Sport OEM dual exhaust on my 3.6L
I'll give some gas mileage opinions once this tank of e85 has run out and I get regular unleaded back in, but from my first impression the truck seems to get better gas mileage and has a much easier time of maintaining speed with little throttle manipulation.
When installing, be aware that the stock intake box on the throttle body side is rigid and flimsy. I split mine on top during its removal when trying to twist the intake off of the throttle body. Another thing I noticed is the throttle body on my truck is pretty loose and wiggles around on the intake manifold. I'll get back in and tighten it up today.
One thing that I thought could have been done better by K&N is the fitment of the air box/heat shield to the inner fender of the truck (see pick below). There are some gaps that could have easily been closed with a little more/better contouring of the heat shield, but they are not so large that I cannot seal them myself. The only reason I want them closed off more is to avoid water infiltration from below (I'm thinking the under body sprayer at the car wash).
