Philips H11 CrystalVision Ultra Upgrade Headlight/Foglight bulb ?
PNW2Tone
Ok, so for LB it would be the Philips H11 CrystalVision Ultra. For fog it is Philips 9145CVB1 CrystalVision Ultra? What about the HB? And are all 3 plug and play with the exception of trimming a tab or two? Sorry for not quite getting it.
If you use the bulbs the truck calls for you don't need to trim anything. And I'm pretty sure the HB was 9005. H11 LB, 9005 HB and 9145 FOG. And I'm driving a 2012.
Sent from my VS995 using Tapatalk
Bert
so if I order the Philips crystal vision 2012 for the headlights what will I need to do to make them fit?
Podcast
Da sticks
Not sure if you're confused. There is no crystal vision 2012 bulb. That's the year of his truck.
tones2SS
MA
3.3 tt
(This may have been asked already, but I did not see it.)
So,.....how hard is it to replace the fog lights on a 2016 Sport? Do you have to take the front bumper off or can you get at them from under the vehicle? Again, just the bulbs, not a full kit.
Thanks!
yortnodnarb
Adrian,MI
Thanks!
If going with factory 9006 bulbs maybe 5 mins for both, easily accessible from underneath the truck. If you go with the upgraded 9012 bulb it'll take maybe 5 mins longer due to having to trim the plastic tabs to make them fit.
tones2SS
MA
3.3 tt
Thank you sir!
I appreciate it.
Eightd21
MI
NA
NA
Fairly sure the 9011s and 9012s can only be had in standard bulbs. Even so, they are brighter than most other halogens and last longer than higher powered 9005/6 ones.
