Pics Requested
durango4819
DE
4.7 V8
does anyone have a 4'' lift with Blisteins and the RCX1.25'' body lift? i want too see what my truck would look like if i added 4'' suspension.
Thor09
Northern PA
I think Jake09 had a similar setup to that. He initially had a 4" superlift but then put in bilsteins and then a small body lift.
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
What Thor ^^^^ said.
Jake09, has 4" superlift, Bilstein set to 1.4" and 1.25" RCX body lift.
I know...I just left his thread. Lol
jake09
Yep I had the 4" superlift, bilsteins at 1.4", and 1.25 bl. on 35s. Heres pics.
Now with bilsteins at 2.1" and 37s
jake09
I'd start with a 6" if i were you. You'll regret going bigger imo. But don't order the 6" superlift if you are already going to use the bilstein front shocks bc the 4" and 6" superlifts use the exact same parts including the diff drops brackets. only difference is the 6" comes with a 2" preload spacer or the bilsteins you already have(upgraded package) and rear comes with longer coils and shocks. I would go with an rcx 6" bc its cheaper and you get 5"or so lift from the strut spacer to begin with before adding the bilsteins.
fastNugly
Toronto, ON
5" im assuming is for the rear with the 6" kit?
I will be going with RCX for either 4" or 6"
Man the 37's look at home
How high were you with the 35's?
to have a 0.5" rake in the front what would you recommend the setting to be on the Bilstein's with a 4" lift kit?
durango4819
durango4819
DE
4.7 V8
thanks for all the pics and info. damn that looks really good. i think id definitely have to go with 37''s when i go for it though. my Bilsteins are at 2.8'' too.
