Pillar Gauges
LS5DodgeRam
South Florida
4.7L v8
I am considering a pillar mount for my 1500, and already know what type of gauges I want. I either want the Mopar series or the dodge factory match from autometer. I am debating whether to get a fuel pressure gauge, or a transmission temp gauge... My question is whether or not the stock 1500 transmission has a **** for the sensor already, or do i need to get it installed at a shop?
I am either going to get the srt-10 style a-pillar, or an autometer dual gauge pod, depending on the hassle with the trans temp gauge.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
If you want a sweep style gauge for trans you can hook into one of the unused test ports on the trans but will require adaptors and other odds and ends. D already said it but the AI series reads all of it and you can just run the SRT single pod and not lose your entry handle. The dual pod is ok but the fit and finish is not 100% like the SRT one is from me owning both.
LS5DodgeRam
LS5DodgeRam
South Florida
4.7L v8
"AI" what does that mean? or is it a company? and yeah I'm thinking i want to go with the srt-10 in order to keep my handle, only thing is i do like the sweep gauges, I'm a little more oldschool in that sense. if i was going to go with digital I would probably go with AEM white faces are nice plus i have used them before
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Aeroforce Interceptor
http://www.aeroforcetech.com/products_interceptor.html
CAN) Vehicles
SR series gauges:
Platforms:
Platform 1: Neon SRT4, Neon, PT Cruiser
Platform 2: Ram, Durango, Dakota, 300m, Intrepid, Stratus, Sebring, Concord, LHS,
Liberty
1.
INTAKE AIR
Intake Air Temperature taken at the throttle body inlet
2. AMBIENT AIR TEMPERATURE
air temperature at
the air filter
3.
COOLANT TEMP
Engine Coolant Temperature
4.
RPM
engine Revolutions Per Minute
5. CALCULATED AIR FLOW RATE
Mass Air Flow (lbs/min) calculated by the
PCM
6. BAROMETRIC PRESSURE
ambient (outside) air pressure
7.
MANIFOL
D PSI
Manifold Air Pressure (boost
psi)
8.
THROTTLE POS PCT
Throttle Position percentage (0
100%)
9. THROTTLE VOLTS
Throttle Position sensor output (0
5 volts)
10.
MILES PER HOUR
Miles Per Hour
11. KNOCK RETARD
Total Knock Retard (degrees)
12.
ST KNOCK RETARD
Short term knock retard
13. LT KNOCK RETARD
Long term knock retard
14. FUEL KNOCK RETARD
ST + LT knock retard
15. KNOCK SENSOR RAW VOLTAGE
voltage output of knock sensor
16. WASTEGATE SOLENOID % DUTY CYCLE
programmed wastegate
Duty cycle, 0
100%
17.
SHORT TRIM FUEL TRIM
short term fuel trim
18.
LONG TRIM FUEL TRIM
long term fuel trim
19.
OXYGEN SENSOR
O2 bank 1 sensor in millivolts
20. FUEL LEVEL
amount of fuel in the tank in gallons.
21. EXHAUST GAS TEMP
calculated/determined by the PCM
22. TRANS TEMP
Transmission Temperature (auto transmission only)
23.
RUN TIME MINS
engine run time since last engine start. Can be used as a trip timer.
24.
BATTERY VOLTAGE
Alternator/battery output voltage
25. BATTER
Y TEMP
Battery Temperature
26. PULSE WIDTH
injector pulse width
27. FUEL TEMPERATURE
28. BASE SPARK TIMING
timing level commanded by the PCM before adjustments due to
temperature, knock, etc.
29. SPARK ADJUST
adjustments made to base spark timing
30.
IGNITION ADVANCE
final ignition timing advance after adjustments
31.
ENGINE LOAD
calculated Engine Load (0
100%)
32.
Miles Per Gallon
instantaneous fuel economy
33. Calculated net horsepower
34.
TOTAL MISFIRES
Total misfires of all cylinders.
35.
P Ratio
Pressure Ratio MAP/BAROMETER
36.
Analog 1
analog input #1.
37.
Analog 2
analog input #2
All second gauges of a dual set will only support highlighted in red parameters due to limitations
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I also like the sweep gauges but for how many of those it takes to do what one of the AI does it was an easy choice for me. Only other way to monitor everything it does is to have the laptop in the truck hooked up at all times if I did a sweep PSI or Temp gauge.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
A video on youtube. Ya can cycle through them, I have not made a movie on mine but you can set it to stay on things or cycle like this is doing.
[yt]8JIrvLQnz84[/yt]
LS5DodgeRam
LS5DodgeRam
South Florida
4.7L v8
wow, those gauges are crazy! I didn't even realize how much they can read, they are a little computer
Bad Habit
Land O Lakes
Modded 4.7l
Aeroforce int. Is the best ive had. I have a extra srt pod it has a alarm led hole in it, ill sell. Pm me and ill send you pics.
on tapatalk from my GS3....
