Please help, dealing with coil spring struts
sullivan
Houston, Texas
ok so today is ******* me off, im in the garage typing this. i got the shocks finally off and now i cannot remove the bolt to get the springs off. i compressed the springs but the center rod just spins. i dont know how to get this stuff apart. its stressing me out. the strut rod has a head, but i can't hold both and put a impact on the bolt at the same time... help
shadow11
Banned
Houston TX
Sounds like the strut/rod is all messed up. I know exactly what you are describing cause I changed the struts on my brothers IS today and it was very easy. Maybe just cut the rod off the old strut to get the springs out.
bigtigga84
dela....where?
Can you get a pair of pliers on the rod? Soak it in penetrating oil might help too.
sullivan
sullivan
Houston, Texas
I've viced the hell out of it with vice grips, and it just spins in them. I need to get a piece of leather or something, maybe a **** tun of duck tape.
Either this or I am taking them to a shop to be removed, or below:
What would I cut the rod with??? Remember I have to go between a slightly compressed spring.
My new bilsteins are the same deal though. is there a special wrench socket that has a hole in it and allows you to turn the bolt and stick a allen wrench inside of that hole?
bigtigga84
dela....where?
Angle grinder, but I think he is talking about cutting the nut off the top
sullivan
sullivan
Houston, Texas
The top nut is not possible to cut off, its sort of in a deep hole.
Im gona try tomorrow i guess, i hope several layers of duct tape and a massive vise grip and the air impact at 125 PSI will a full tank.
I feel very successful for someone whos never done something like this.
sullivan
sullivan
Houston, Texas
So me and the pops went out and gave it a wack together. And we broke a socket turning the bolt. that fukken thing is stuck. im taking it to a local auto shop and ask them to help me out, my family just did over 5k worth of work with this man. hes a honest good man.
btw, it was a craftsmen socket. buy it once, and only once. :)
RubberFrog
Just cut the shaft. You can get in there with a sawzall. This is a semi common problem.
sullivan
sullivan
Houston, Texas
Oh god are you serious? I can't seem to get my craftsmen saw to setup right.
Oh my god this is a pain in the ass, shadow how did you do it.
shadow11
Banned
Houston TX
The nut just came right off for me. No problem at all.
sullivan
sullivan
Houston, Texas
Darn you. This must have been the ******* fault who installed the shocks on the previous owner. They must have not torqued the bolt down correctly. What a ********. I am honestly tired of working on my truck now, everything I touch is either over tightened or stripped on the head. I have to take these struts to a local shop, NO major shops will touch my struts, and it ****** me off. They won't even just compress them and undo the ONE bolt for me.
shadow11
Banned
Houston TX
Just the strut. I want to see if there is something else you can do.
sullivan
sullivan
Houston, Texas
Honestly, I've gotten so stressed to even deal with taking a photo of those ********. I'll put some up of the sweet yellow (the bilsteins) my truck's getting on her though. I finished the rear shocks on day 1.
While doing this work, I've realized I want to replace the following:
sway bar links
upper and lower ball joints
inner tie rods
And then I will have a nice reliable in perfect shape truck.
joshhhh
