Please help! I think something in my steering is broke?
1992DodgeRamD150
Oregon
What up everybody? I’m new here, I just bought my first Dodge truck at an auction a couple weeks ago, it’s a 1992 Ram D150 5.2 318 v8 regular cab 2wd. Anyways.. When I got it home and noticed it was not turning left very much at all, and when I turn to the right the wheel turns wayyy too much. The steering wheel also falls to the right naturally and yet it means it is going straight. Any suggestions? Or tips? I can post pics tomorrow of the steering turning left and right
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
not sure I'm picturing it correctly but it almost sounds like you pitman arm is not "clocked" right on your steering box.
crazzywolfie
under the truck
if the steering wheel is not sitting center like you are talking about it is generally not that the steering wheel or pitman arm are clocked wrong. it is generally that the tie rods are not adjusted right for the truck. it is usually pretty easy to adjust the tie rods to correct it. you mark the adjuster bolts and mark the adjuster. what you rotate 1 adjuster you rotate the other adjuster the exact same until you get the steering wheel sitting just right. i have found a pipe wrench works perfect for adjusting the adjusters.
reek
Sacramento
it sounded less like his steering wheel was a little 'crooked' but more like his wheels were turning way more one direction and not enough in the other direction. but like I said, I could be picturing it wrong. maybe OP could post pics or clarify please?
crazzywolfie
under the truck
but i believe the pitman arm can only go on these things 1 way since there is a special line down the 1 side to make sure it goes on 1 way only.
FCA Master
West Texas
As Crazzywolfie said, the pitman arm can only go on one way. Someone has misadjusted the tie rods. Many people don't understand setting total toe and then straitening the steering wheel on this front end set up. The tie rods need to be adjusted properly as Crazzywolfie mentioned.
reek
Sacramento
didn't even think about this fact. embarrassingly, two weeks ago I just put an entire new steering, including box and pitman on my chevelle. same thing, keyed so it can only go on one way. gotta really lay off them IPAs...
1992DodgeRamD150
Oregon
5CEE545A-A467-4958-AD73-6BEF236B6A8F.jpeg DF4F49E8-8EBB-459B-974F-C7A691E26150.jpeg 34FB7BD1-5082-493F-B5D4-017E1239D420.jpeg 4C185A09-D15E-4E43-BAC1-2E52A688994F.jpeg 34FB7BD1-5082-493F-B5D4-017E1239D420.jpeg Hello everyone thanks for the replies and suggestions, here are some pics of it fully locked left and right, I have just been poking around underneath trying to figure it out, if any other pics will help please let me know
crazzywolfie
under the truck
have you checked to see if there is anything between the spindle assembly and lower strut rod on the drivers side. the spindles usually stop when they hit the strut rods.
dakota18
