please help
boarderkidd11
i have a new prroblem my 2001 dodge ram 1500 it is running rough i cant get it to idle at the reccomended rpm"750" i reaplace the tpc and it ran at 1000 for a good ride then went back down to 600 what could cause this? my engine light has also been going on and off i checked the code it was p0123 and i also changed me tpc what else can i do to fix this?
txbass06
NE Texas
5.9 Magnum
There's an Idle Air Control sensor located on the back of the throttle body. Try pulling it off and cleaning and see if that helps any.
Is the truck running good other than the idle issue?
Sent from my iPhone 4 using Tapatalk
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I'm with mark on this one. Make sure there are no missfires.
boarderkidd11
boarderkidd11
no missfires but i cleaned the throttle body and sensor. now the truck eventuallly got up to idle at 1000. the code p0123 went away now i have a diffrent code po121
adamwilkes14
The P0121 is for a TPS...is it blowing black smoke at all when you accelerate? Is the harness for the TPS rubbing against anything on the engine? It could be a bad TPS out of the box, can't say it hasn't happened before.
boarderkidd11
boarderkidd11
i went to pull out the tps and it popped open and cant get it together so i put the old one back in. i had the tps upside downthats why i think the code came on and also i washed the engine and possible could of got water in it. but i still can not get it to idle at the recomended 750 any ideas?
txbass06
NE Texas
5.9 Magnum
There's a guy I worked with that had the same problem. Make sure there's an o-ring around the tps when it's on the throttle body. He got sold 3 from autozone without them and were all bad out of the box
boarderkidd11
boarderkidd11
i have a gasket on there should i change it to the o ring?
txbass06
NE Texas
5.9 Magnum
I haven't had mine off but I've never seen a tps gasket for these. Just the o ring. I'll take a pic of a new one tomorrow if that'll help any
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I had mine fall apart in my hand when I took the bolts out. I don't remember there being an O ring but it could have stayed on the TB.
txbass06
NE Texas
5.9 Magnum
A new tps should come with an o ring and a gasket. If the sensor has a groove around the base, use the o ring, if it doesn't, use the gasket
txbass06
NE Texas
5.9 Magnum
Lol I do whatever I can to help. Whether it be pictures or descriptions or prices
boarderkidd11
boarderkidd11
ok thankss. i just kept the gasket on. im going to buy another tps hopefully that will help
boarderkidd11
boarderkidd11
i was driving my truck today and i was going p a hill when i had the gas all the way down my rpm just kept dropping so i shifted down and it still happen and the my engine light came on with the code p 0123 what should i do?
boarderkidd11
boarderkidd11
so if i change that do you think that my problem climing up the hill would be fixed?
ramthis9501
Oklahoma
5.2 V8
Just an idea, but maybe the cat might be clogged... that's what I'm thinking with my truck right now, it lowers overall engine performance and I read a few things that said the exact thing that you are and they had a clogged cat
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Check your cat to see if its glowing after you have driven it, then you will know if thats plugged or not
joshhhh
