Poly Rear leaf spring bushings and shackle question, 04 1500 4 wd
Joe.G
2004 SLT Quad Cab Short Bed
Hi, I just ordered a set of Black Energy suspension rear Leaf spring bushings, They are marked for a 2 WD but everything I have researched show that the 2 and 4 WD use same factory bushing.
I also ordered new shackles since the bushing in them are getting to look a bit rough, Any tips are changing this stuff? Is it worth it to go Poly or should I have used Rubber?
Am I right that 2wd and 4 wd use same bushing?
Will I notice a difference?
I also ordered new Bolts and Nuts.
usaf2006
North Carolina
Should be the same. From what I understand, poly will out last rubber but may squeak occasionally.
