poor control on highways
stevens
2015 Dodge Ram sport 4x4 crew
going to bring my truck in tomorrow to a tire shop. i got horrible control on my truck at high speeds. it kinda wonders back and fourth....doesnt drive stright...also i have alot of play in my steering wheel.... i got 37"s with a 6" zone lift....but i dont recall my steering having this much play and poor control on roads...any ideas? i think i lost some stick weights...maybe its unbalanced...?
Rzrman328
The treeline
First thing that comes to mind is worn tie rod ends....but your ram is fairly new...hmmmm
Is there knocking noise on slow turns?
How is the wear on your tires? May be an alignment issue too....
stevens
stevens
none of that....it honestly feels like the damn winds are going to blow me off the road like its that bad. i almost barley feel attached to the road.
ExpressRules
Southern New Jersey
2019 Big Horn Crew Cab
I have to think that running 37's with a 6" lift cant be helping you at higher speeds.
Rzrman328
The treeline
But your steering wheel feels loose?
Or....is the steering wheel tight and the truck feels loose/wobbly?
If you haven't already....crawl under that sum_itch and inspect everything before you drive any further. Disaster could be lurking.
stevens
stevens
my steering has lots of play. turning is fine no cracking or anything...just when im crusin it just feels like theres a massive wind storm and my truck just feels like it wants to wonder.....
WilliamS
Tampa FL
Hmm, tie rods, horrible alignment, a tire way under or over pressure, popped a ball joint.
If its that bad get under there and do a visual. If you hit a bump is it making a lot more noise than usual. Something is wrong and can end badly.
stevens
stevens
yeah thanks guys im bringing my truck in a shop tomorow morning to check all my components.
