Removed side badges this weekend from my 2014 RAM Sport. Used fishing line, pulled 3M tape off using the pulling back at 45 degree angle method & Goof Off to remove leftover residue. Everything worked perfectly & looks great. However....
When I bought the truck the dealership "Covert in Austin on 183" fixed a paint chip next to the antenna mount. The tech that sprayed the panel taped over the HEMI badge instead of removing the badge to paint the panel. As you can guess when I removed that HEMI badge I found a very distinctive paint outline from where the badge was. Covert did not want to step up to the plate and fix this for me, for some reason this is "the customers responsibility for removing the badges" even though they were the ones that did NOT prep the panel correctly in the first place before they sprayed it.
Do I have any recourse here our is this on on me???
Pissed but not shocked at dealerships lack of quality & customer care.
