Ported Box Design Help
the codes
Houston, Tx
Magnum 5.2
Okay so I wanted to make a ported box because its more appearance freindly then a plain old sealed box, but I need some help on the calculations, if there are any? I know close to nothing about ported boxes. I have come up with a design, and for you audio techy guys out there, let me know what you think or if you can help me out with the design I can post measurements.
Or if you think I should just do a sealed design let me know. Be brutally honest and if you need anything for a better idea just let me know.
going for something like this
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Looks like an ok sketch. Hard perspective to see it all. What material are you wanting to use? Wood/resin? Plastic? I see you plan on plexiglass lids. How big of subs: 10, 12?
Think you should measure out the sides, angles so we can see depth, and a better overall view.
the codes
the codes
Houston, Tx
Magnum 5.2
I was going to use MDF wood. prob 5/8'' or 1/2''.
also just thought, should I have the port to the back or to the front of the box?
Rough estimate measurements, will get more accurate ones tomorrow.
Im planning on lifting the back seat up 2''s with a rectangle tube as a spacer.
so the approx measurements will be
front of bench to floor-->13''
back of bench to floor-->5.5-6''
side to side-->roughly 6'
end of bench to floor (hump)-->9''
back of bench to floor (hump)-->3.5-4.5''
did I leave anything out?
also need to leave space on the front corners for the handles to lift the seats
and yes I plan on using plexiglass on covers to give the box some flare. or a tougher similar material.
HKkid
Missouri
Just do a sealed box. You aren't going to get the airspace in the box for a port to sound good. As l so there isn't enough airspace in the cab. I had a ported box in my XJ and it sounded great, but there was plenty of airspace. Also I would never use 1/2 inch mdf. 5/8 at least, and I always use 3/4.
Hotroder383
Washington Mo
318 or 5.2 which ever you want
the codes
the codes
Houston, Tx
Magnum 5.2
thanks guys, great information and exactly what I was looking for. Glad I posted here before diving in. Will go with a sealed box, thanks. Ill post pics later guys.
