POS radio
blackram1979
hemi
I have a 2014 2500 with the 8.4 uconnet nav radio the problem I'm having is the radio cuts out in any mode (Radio, surius,aux) the dealer already replaced the radio 4 times and the amp once I've come to the conclusion they don't have a clue what the problem is. Has anyone had the same problem if so was it fixed and how ?
Etroze86
Grand Forks ND
That's interesting, what kind of cutting out is happening? like screen completely shutting off or just sound?
Jared4.7
Olathe, KS
2017 Bighorn CC
There's an update for the amp that just came out. Try that yet?
Sent from my SPH-L710 using Tapatalk
B
blackram1979
hemi
Just the sound it can last 2 sec up to10 sec
B
blackram1979
hemi
I have not tried the amp update I will have to look in to that
ramd
Has any one figured out why you're radio was cutting out? Mine just started to turn all the way off and then comes back on. It does it a lot sometimes and then it will work fine the other times.
RamCares
n/a
n/a
Has this been addressed at all by your dealership?
Kori
Ram Social Care Specialist
ramd
Yup. The first radio I had would get stuck on the back up camera and turn off so I had it changed by the dealer then the second radio worked great then out of the blue it started to shut off
RamCares
n/a
n/a
Have they had a chance to diagnose this new occurrence?
Kori
ramd
No. They said the programming then it was the radio so they changed it. I haven't had time to go to the dealer and leave my truck there
wutech
SE WI
I have heard the repeated 8.4 problems can be due to bad grounds? A bad ground on the trucks electrical messes with the software running the computer in your dash, fix the ground problem goes away, problem is finding the ground issue.
mitey22
Georgia
subscribed...my 2017 has gone out a few times all of them while listening to satellite radio and I thought it was an xm problem. now im wondering
Jantelaw
