Power drain
Matt2221
Oregon
Hi folks, I'm new here so hope I'm doing this right
I have a 2013 Ram 3500 diesel.
When I park it overnight the battery drains down to 10.6 v. I've checked all the obvious, under hood, lights, seat buttons...everything. any suggestions? Powers draining somewhere.
Elvira
Somewhere
First culprit to check is your battery, age of it and maybe do a voltage drop test. 5 yrs is a rule of thumb for battery. Fully charge the battery with a good charger and then do your voltage test.
M
Matt2221
Oregon
They are 2 years old but I did test them both. Also tested the alternator.
M
Matt2221
Oregon
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
If you can get a hold of a DC amp meter, you can place the meter around the battery cable, take note of the amount of current draw, then pull each fuse individually until the current draw disappears. That should help you to know at least which circuit the draw is coming from. Make sure to not start the test until the truck has sat for a while so the ECU goes to sleep.
I have seen aftermarket remote starters and alarm systems drain a battery so might also disconnect these if you have any.
I would try disconnecting one of the batteries and let it sit overnight, see if the problem persists with either battery disconnected.
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
:party36: :welcome: :party36: Make sure the batteries are clean, especially between battery posts.
M
Matt2221
Oregon
M
Matt2221
Oregon
Ok fellas, I finally got the correct meter and I think I have it narrowed down to F-23 which says CBC#1. Any ideas what that is?
JohnnyMac
I believe that is your Central Body Controller. Unfortunately that controls a ton of stuff so here's a couple things to read up on for it that might help you to narrow it down.
Make sure this Recall has been completed.
**On a side note** If you have a built in light in the engine compartment that comes on when you open the hood, make sure the switch is good and that it actually goes off when the hood is closed. Also double check your door switches and make sure the interior lights go out when the door is closed.
george55378
Tower,MN
Pull fuse m41. Sometimes the infotainment system will keep coming out of sleep mode and can cause this. I recently diagnosed a 2013 with same scenario and found starter Solenoid drawing current due to bad winding insulation. Pretty Profound. Strange Anomally. Big time bearing play too! Replaced starter. All good. The first i mentioned try first tho. Electricity is a funny animal! LOL!
