mamboloco
Hi,
I recently installed refurbished bosh 4 port injectors and the truck starts, idles smooth but has very little power. to get it going I almost have to floor it.
I've checked the connectors to make sure they are plugged in the right order. Anything else that might cause this? There are two connectors near the throttle body that I disconnected for better access and I plugged those back in, I assume they have different sockets and I didn't switch those around.
No fault codes
Anything else I should look for?
Thanks!
mamboloco
2002 Dodge Ram 1500 Magnum 5.9 V8 STD Cab LB
No fault codes
Thanks!
mamboloco
