power outlet help
Mdunntn
I have an 06 quad cab with the large center console. My passenger side outlet and my in console outlet both work. My driver side outlet and the outlet on the rear of the console however do not work. Should I be looked for a blown fuse for those two outlets or should I just reinstall new outlets in their place.
Squidbilly
Most likely a fuse. Just to check, you did try those with the key turned on right? In my truck, passenger side is always on while driver side is only on when the car is on.
M
Mdunntn
Yeah they have never worked since I have owned the truck. I'm in the process of tearing out the interior so want to make sure everything is working before it goes back together
