Power seats
Tommuise
Georgia
5.9 Cummins
Loading truck for trip this morning (03 ram 3500 Laramie) and slid power drivers seat all the way forward and now neither driver or passenger side power seats work. Tested fuse and it is good. Even switched with another 50 amp and….nothing.
MrBonez
Central Alabama
2008 Laramie Quad Cab
Could be a relay/solenoid gone bad, if you check and find you have one in the system check it and see if it's OK.
I'm not familiar with the system myself but normally you'd have something to control actual power flow when triggered by your seat's switch being used, like solenoid would do somewhere in the system.
That would explain the good fuse, seats not working issue if so.
ChloeBrooks
