power wash
Jonathanther
Hi guys, i pressure wash my new white ram 2017 this weekend and I think that I make a mistake. I have an electric pressure wash 1800 psi and i tried to remove the dirt with the 15 degree angle on the nozzle. But in the instruction it said that this angle can damage paint. Do you think that I damaged the paint or the clear coat ?
thank you
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
Other than visual inspection it's hard to say. Unless you held the nozzle very close for an extended period of time in certain spots I wouldn't be concerned.
I use a light duty electric to clean mine up as well (well water pressure sucks!!). For washing I keep the nozzle about 2'-3' away from the surface and only go in close when cleaning wheel wells.
stimpy433
IOWA
You'd know if you damaged the paint.... it would be missing off your truck!!!
joshhhh
