5th Gen 2023 Ram | 5.7 Hemi Etorque Misfire Fix
ryans3140
NH
Hi All,
I bought a 5th gen 2023 ram w/ the 5.7 Etorque earlier this year. The truck (only 10k miles) was in the shop for 38 days due to a P0306 & P0300 code. Dealership couldn't figure out problem.
Dealership contacted Ram Engineers and opened a star report. The dealership was very kind to provide a rental car (Chrysler voyager minivan). In case you're wondering, yes, I did get made fun of.
After 38 days, the dealership had contacted me that they had unplugged and replugged some connections as well as used fuel injector cleaner and the misfire disappeared. Certainly don't feel great about it but the misfire has been gone and put roughly 5k miles on the truck since then.
The reason for this post is to relay what the engineers recommended in case anyone else has a similar problem.
Star Report:
1. Fuel Pressure test, Fuel Pressure leakdown, Fuel sample (check for contamination), perform compression test and leakdown test.
a. everything passed Right bank (2,4,6,8, cylinders around 120-135; Left bank 1,3,5 @ 127 and 7 @ 136. Fuel pressure was 59 PSI.
2. Check MDS Solenoid connectors for damage, corrosion, bent terminals, or any irregularities. Also, check the engine & intake manifolds for any vacuum leaks.
a. all passed
3. Perform Block pressure test overnight to inspect for irregularities. Also, inspect spark plugs for any fouling, carbonation, and irregularities. Also, check cylinder 6 using borescope for scoring or other degradation.
a. all passed, no sign of coolant with borescope, checked pressure gauge and the gauge stayed at 15 psi over the weekend.
4. Monitor fuel injector pulse width and see which one is off, one will be at least 15% higher or lower than others. The issue may not be at idle, so recording different rpm ranges is helpful. Once you determine which cyclinder is the issue, measure resistance of injectors and compare. Try swapping that injector to another cylinder, reset fuel trims and reevaluate to see if you have a plugged or leaky injector.
a. misfire is still happening on cylinder 6, cylinder 6 & 8 a little off from the rest. Put in fuel injector cleaner and let the vehicle run for a while. Test drove vehicle and misfire didn't return. Vehicle operating as normal.
Hopefully this was helpful for anyone with a similar issue and is out of warranty.
Thanks!
Ryan
Dodge 1500 4X4
Rochester, NY
Sorry CYSA, at its finest all of those tests were taken out of a training course textbook, all they did is fill in the appropriate numbers or letters, probably took them 1-2 hours to fill in the blanks.
And their Star Report should be Brown Star Report!!!
Also 10,000 miles fuel injector cleaner????????
R
ryans3140
NH
The technician waived the magic wand over my engine bay and Check engine Light disappeared. Nothing short of a miracle.
I feel like I’m driving a ticking time bomb. Fingers crossed. I’m not mechanically inclined by any means. I wanted to post just in case any of that textbook lingo was helpful for someone. Thanks for the reply!
Dodge 1500 4X4
Rochester, NY
It could have been dirt in the injectors to cause a misfire, put some Redline Sl-1 complete fuel system cleaner, put 15oz bottle in a near empty fuel tank and fill W 20 gallons of fuel see if that helps it should quiet down noisy injectors and clean injectors.
Get on a Lubrication strategy W those low miles
7 qts Redline 5w30 full synthetic motor oil W royal purple 20-820 oil filter 5,000 oil change intervales.
seems fishy
Ontario
His truck is supposed to take 0w20 oil.5w30 will void the warranty.It doesn't seem to harm my 2023 hemi engine however .Welcome too
