Power Window Issue - All work except rear passenger
SeanJuan
San Diego CA
The rear passenger window will not work from either driver switch or door switch.
All other power window work fine.
Do you guys have any ideas? I think it may be the window regulator
first pick up a set of plastic trim tools
you can buy them anywhere, auto parts or Hardware store carries them. the reason for using Plastic, it will not scratch the interior or exterior.
Then pry the passenger door switch up
spray the contacts with electrical contact cleaner & work the buttons
You may have to check out the passenger door switch, to make sure the electric plugs are seated
rockmanm35
SW VA
I had a similar issue on a F-150 and it turned out that the wiring bundle had been cut by closing the rear door repeatedly. I had to reconnect all the wires as most had been cut.
Xyleff
California
did you figure out the issue? I have similar problem but i might start with window motor first.
VA-RAM
STL, MO - Norfolk, VA
2017 Laramie / 2020 Laramie
^ +1 on this post by rockman.......same thing with my rear drivers door...also affected the door lock intermittently. Re-do the wires in the loom between the door and the cab...
S
SeanJuan
San Diego CA
I want to follow up it was the wiring connection on the drivers side door
Arturo Rojas
