Power windows not working
Russman
Hi new here....but power windows used to go up/down...then sometimes stop..and the rear slider....then just stopped....changed the drivers side master switch...power mirrors work...no power in pink/yellow striped wire into switch....no power coming out of the control switch by the parking brake...no power coming right out of back of TPM.......what's my next move. (Yes key was turned to on position and used a multimeter not a test light)
R
Russman
I was told power always runs from the TPM to the circuit connector by the emergency brake...and there is no fuse in the box?
m4mckeen
There's gotta be a fuse I would think
Phil fix this!
So. California
4.7 v8
If you haven't found the cause yet, check your wiring between your driver door and frame. I have found broken wires that have caused similar power window problems.
joshhhh
