Power Windows
RonVez
Ontario;CANADA
Hey all
Question????? Master Power Window switch,Im pretty sure that when I got my 17" it had intermittine control for front windows each time push/release windows lowered stopped hold switch 1-2 seconds windows completly lowered
same in reverse when closing windows
Now appears just touch switch and windows lower/raise fully
can stop the up/down by touching switch again but i'd like to get that inttermitent conrol back
any ideals?
I do have the AlfaOBD/VEEPEK app if needed but not sure which function its under
Thanks
GordDavey
Toronto, Ontario
The windows switches work such that when you press them halfway down the window goes down and wil stop when you release the switch. If you press the switch all the way down, then the window goes all the way down even if you let go of the switch.
So nothing to do with push and hold of switch and everything to do with how far your press down or pull up on the switch.
There is also a setting in the BCM for the global up / global down for the windows that can control this behavior as well.
Tom24
NH
I have read that if you have window up you push and hold to go down then hold for 3-5 seconds then push and hold for window to go up and hold for 3-5 seconds and that will fix it.
