Preferred mini antenna?
Corvette427
PA
need to move the stock antenna for the snorkel. Any recommendations on a mini antenna? Thanks!
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
I have a Cravenspeed 6" which i love. I live in a metro area so reception is good, 8.5-9 out of 10
gofishn
Iowa
hemi 5.7L, 345 cu in
OR, just spend $20 and get a 9 inch black Antennae off amazon, like I did.
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
I second the Cravenspeed. They actually did some engineering to make sure the antenna is cut for the proper radio wavelengths, whereas some of the cheap Chinese knockoffs are just cut short and don't have baluns etc. to match signals.
https://www.cravenspeed.com/the-stubby-antenna/
scoutpappa
2017 dodge power wagon
12$ rubber 8" job at Autozone. Works like stock (basing that off of radio stations that I listen to and distance from source), along with the AVS deflector and in channel window visors, really cleans up the exterior. Now on to finding the right set of 35's after the stock tires wear out.
Sdreeser
Maryland
6.4 hemi
I have the original stubby from cravenspeed. Looks great and good quality. Not sure how good reception is I only listen to Sirius xm radio
Low_Sky
6.4L
I use this one when I off-road.
