Premium Cluster Upgrade
appzattak
Jerome, Idaho
Just upgraded the EVIC in my 2017 1500 Express. All looks and seems to work fine. Only thing I notice that is not right, is the Fuel Economy Screen is blank. Anyone know if that is normal or not? The Trip A and B do show it there.
appzattak
appzattak
Jerome, Idaho
never mind I figured it out, I just had to push the left-right arrow and it showed up
Dave2018
2018,Previous 1998
3.6L,Previous 5.9L
Which premium speedo trim does your's show as the start up graphic? Were you able to specify that when they programmed your vehicle run time and mileage? Just curious-Thanks
appzattak
appzattak
Jerome, Idaho
It did show Power Wagon.. I changed it tobRam 1500...did so with AlphaODB. Also you can adjust the idle time with it. Guy I bought from did the mileage to match mine
Sent from my Pixel XL using Tapatalk
WTM75
Upstate NY
3.6 Pentastar
I did the same...minus the run time, that was not available through AlphaOBD when I did mine. I had Navrepair do my mileage and drive/run time, but I don’t recommend them.
