Premium tail light - turn signal
jquattro
All - need advice. 2015 Laramie with original "Premium Tail Lights". Have intermittent warning that rear pass-side turn signal is out. There is only one bulb in the there that's replaceable and it looks to me to be the back up lamp, as its on the bottom of the lens. My manual says "LED Serviced at Dealer" where the replacement bulb should be listed. Any ideas on how I can replace the LED turn signal lamp?
Muchas Gracias!
zacbar
Ontario
Only the reverse lamp bulb can be replaced. The LED brake/turn part can't be replaced. Look on this forum, craigslist or Kijiji for replacement tail lights, there's usually lots for sale and way cheaper than what the dealer will charge
stimpy433
IOWA
Are any of your leds burned out in the brake light??? Check your 3rd brake light, as it will give you the same warning if it's out. There's not a "3rd brake light out" message....
J
jquattro
Thank you - also have a '15 GMC Yukon and the tail LED was a whopper to replace ($) too. Have a new one on order for the 1500. Enjoy the holidays.
The Laramie style LED taillights which have the chrome trim are easier to find than the sport versions (no chrome)
I would check www.car-part.com
Tach_tech
5.7L HEMI
Are you getting an actual message saying “passenger rear signal out” or is it just a picture of the truck with a rear light out?
If you have any brake light out it will just show a generic picture of a truck with the passenger brake light out. It doesn’t actually show which light is out.
clifford15
RI
CTD
Did you check the 3rd brake light?
Kmiko
