Pretty good or average?
turkeybird56
Central Texas
OP, U get 18 +++ on a stock motor be happy. That 23 ish be more like with MDS active running 4 cylinders on a flat road. I can get 21-22 on MY 19 (5th Gen), but usually just stays in the 18-19 if I am under 75 mph. The 23 is the estimated with less skinny pedal pressure, hee hee, especially on a 2015 with 136K on the clock, pretty awesome actually.
You forgot to add in downhill with a tailwind :Big Laugh:
turkeybird56
Central Texas
Did not want state obvious, but I do have a full tonneau cover so changes that Back Pressure additives, lmao. MOST I ever got was hand calc 21.9 MPG on a trip in Aug 2018 actually when truck was brand new, in NC on a trip, with SRA rubber. Now I got Falkens on the truck, and any number at 20 or more is golden with heavier meatier tires,
MyNewRam
Baltimore, Md
I did some highway driving last week. I have a ARE topper on the back. I was averaging 23. Commuting to work(all back roads) I’m averaging 18-18.5. It’s going into eco most the time.
Side note, I’m not really digging that 8th gear in eco mode. With the exhaust, it sounds like its running on 2 cylinders.
turkeybird56
Central Texas
What is it at 75 mph?
I lose 1-2 mpg anything over 75 mph. Over 80-85 I am down to like 16 ish, maybe a bit more, maybe a bit less, that speed depends upon traffic and wind direction.
Pulling trailer: I stay in the 12's. But I also drive defensively and maintain cruise on as much as possible at cruising speeds.
Kraken
Kraken
Nope, I did not just reset it..
No like I said, flat even road, no wind at all.
Obviously MDS was active as indicated by the green 'ECO'.
Also, the speedo can be seen, it was doing like 62-3 mph.
Engine-wise it's all stock still, no changes at all. My bad.. I did throw a catch-can on there a few days ago but that wouldn't affect efficiency in the slightest. Factory 20' wheels and a Bakflip bed cover. And the no-name branded HT tires that come in at 31.59# and they're at the factory 40psi.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Here you go, comparison photos different trucks.
1st photo
My 16 laramie, 5.7 4x4, 3.21, 8 speed in 4x4 lock. Last winter on an airport run, left late. Avg fuel economy
2nd photo
My 14 RT supercharged, 8 speed, 3.92
Freeway between Virginia and Tennessee. Instant fuel economy
The supercharger makes the 5.7 more efficient, IMHO, as well as the RT is less weight.
Kraken
Kraken
Damn I wouldn't have expected a full sized truck to get that good with FI. You can't beat that with a stick.
