Problems staying running
97CAMORAM
In the morning it will crank and turn over but will die. It has gotten worse as we have gotten into winter. Once it has been started and ran for the drive to work it starts fine the rest of the day, but after sitting over night it returns. I have new O2 sensors, tps, iac. Any ideas?? (I have rev and keep rpm's to about 1500 for 6 or 7 minutes and slowly let it down and it will idle but has to idle a lil while longer or will die while coming to a stop.
97CAMORAM
I looked at it. im not saying that its not the problem, but I don't use oil, it idles fine after starting, no pinging or smoke. idk just kinda lost on this one. any idea what the plenum repair would run?
jf5.9
In the Woods in Ohio
5.9L
When I did mine I had $130 in the kit then you have to figure on coolant for the whole system.
There is a guy on ebay who sells plates he has lasered himself. DodgeDude94 knows more about his parts/quality I would hit him up about it. I just ordered the Kit from Hughes.
It can be done in a day if you stay at it and don't have any problems.
97CAMORAM
OK Cool, that may be a job for spring time lol its -2 with ice and snow all over right now.
jf5.9
5.9L
That's what it is here to the degree. just throw a tarp over her and stuff a salamander in there with you
:grd: or your :****sweak:
I was lucky enough that mine went bad in June, but i was out burping my coolant system last night so i know the suck.
97CAMORAM
Haha yea its pretty bad but im ready to get started on my project list. I want her ready by spring/summer so I can have a lil fun.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Judging by your symptoms, have you cleaned your throttle body and IAC valve/passage lately? It's sounding as if, while the engine is cold, the IAC isn't opening enough to get hte engine to idle.
As for the plenum plates, last I heard, that eBay seller (and modded Magnum enthusist) isn't cutting plates anymore for some reason. :( He put out a good product at a good price too, which is a shame. So the only one making plates that I know of is Hughes. APS used to make plates, but I dunno if they're still operating.
quadcab
360 Magnum
I would also check your battery and alt. These trucks will not hold a idle if voltage is low.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
97CAMORAM
I replaced the IAC and cleaned the TB, but I do need to remove it and clean it properly and completely. yea that is a shame he stopped selling them, its hard to find good quality parts. thanks ill check the battery and alternator.
97CAMORAM
Has anyone had issues with a strong gas odor after filling the tank? sometimes it looks as if fuel has ran down the side of the tank but not much.
quadcab
360 Magnum
Fuel pump module seal may be shot so its running out the top of the tank. Its not exactly common on these but I have seen it before.
97CAMORAM
If the seal is bad, it would probably cause a drop in fuel pressure. I def need to check it out.
quadcab
360 Magnum
No it would not. Im referring to the seal between the top of the tank and the pump module.
joshhhh
