Projector help!
OceanRescue01
So my projector is bouncing around in the housing. Help! Not sure how to post video but it is wiggling north/south. Not sure if there is a clip or something that broke
OceanRescue01
OceanRescue01
So I pulled back on the projector and one side popped back in and I noticed this. Looks cracked. Any suggestions? The base of the bolt there.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
If its cracked the only way to get the projector out is to open the headlight = PITA. So I would snap it back flush to where it needs to be, mix up a bit of JB weld and use a swab or something to smear it on the crack thick. It will bond and hold it forever. The JB weld takes lie 12-24hrs to cure and it will run if you install the headlight so my idea would be to lay it flat on a table (lense down on a towel) and do the JB weld. Then let it sit over night/day and reinstall and you should be good to go. Or if the truck is under warranty see what they will do at the dealer, they will more than likely replace the whole headlight if thats the case.
OceanRescue01
OceanRescue01
Thanks! Running to grab some crazy glue now. I’m at work so I can’t take the time to jb it right now but that would be next step
blackbetty14
CT
I wouldnt bother with crazy glue. IF it doesnt hold your going to be fighting adhesion with the JB weld. So you wont get as strong of a bond. Also once you try to fix it... it wont be warrantied... so if your going to try to fix it dont bother trying to get RAM to take care of it.
capebreton1967
