Puddle light connector
mdk2
PA
5.7L V8 Hemi
I have a 2018 Ram 1500. I didn't see this talked about anywhere else on here..
I was removing my puddle lights and putting in sequential replacements.
When I removed the plug-in from the passenger side connector one of the prongs remained in the connector and it is stuck in there. I can still put the old puddle light in and it works somehow.
I called a dealership nearby and explained this and they said I will need a whole new mirror, is that really my only option for replacing a little plastic piece that 3 cords run into?
Anyone ever dealt with this before?
Thanks!
caulk04
Supporting Vendor
Seems that none of the parts to the mirrors, except the glass, are available separate from the assembly. Rather annoying, but that's how it is.
Stop by a junk yard, maybe you'll be able to find a busted mirror for cheap that you can steal parts from.
Titeman2000
Sault Ste. Marie, MI.
I recently come across this puddle light delema. Went to change light and pegs from old light broke off in the plug. At $50.10 for a new plug, I decided to fabricate my own. My best bud come up with using a 4" wire jump with a butt connector on each end. He trimmed the plastic back on one end and plugged into new light. Sealed entire connector hole with hot glue gun. Used butt connector on the20210908_174052.jpg20210908_174052.jpg20210908_174300.jpg other end to attach to stripped wire coming out mirror. Both ends sealed with shrink tube. Total cost of repair, $3.60
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
The parts dept. sells mirror glass & puddle lights
The Service Writers are told to UPSELL products
They will not tell you about the mirror glass & puddle lights, unless you bring it up
If the tilt motors go bad, which is unusual, they are easily replaced
If your mirror housing get cracked or shattered, you can buy new ones from various places, you may have to get them painted, they come in textured & smooth black
Heck, i think even the temperature sensor that is in the drivers side mirror is available
Kinta77
US
Thanks!
Kinta77
US
Mine is 2011 and i had same problem , same. I bought the led and they dont work , check your old connector and compare with this one PT2834 . I think is the same , if you buy the led , before reinsert the housing make sure they both work ( cortesy and signal ) .. Depends the brand , one of side lamps the connector inside the lamp is inverted , that means you will need to invert the wires in one of the lamps ... thats why before doing a solid connection try both sides first ...
Kinta77
US
Thanks!
You DONT need the whole mirror , just replace the connector This what you need 68064949AA on amazon , compare it with the one in your truck
Kinta77
US
I recently come across this puddle light delema. Went to change light and pegs from old light broke off in the plug. At $50.10 for a new plug, I decided to fabricate my own. My best bud come up with using a 4" wire jump with a butt connector on each end. He trimmed the plastic back on one end and plugged into new light. Sealed entire connector hole with hot glue gun. Used butt connector on theView attachment 470380View attachment 470380View attachment 470381 other end to attach to stripped wire coming out mirror. Both ends sealed with shrink tube. Total cost
,Same here , I just bought a new sequential led's paddle lights for my Ram 1500 . I pluged it in and they dont blink the way they should . The only thing i did was replacing the connectors ( old ones were rusted ) . But gauge are diferent . The new connectors wires are thicker. And thats the problem , I dont know if the relay is the problem or the connection of two diferent gauge.... Can you ask your buddy what the hell is going on ? ...
Thank you
I recently come across this puddle light delema. Went to change light and pegs from old light broke off in the plug. At $50.10 for a new plug, I decided to fabricate my own. My best bud come up with using a 4" wire jump with a butt connector on each end. He trimmed the plastic back on one end and plugged into new light. Sealed entire connector hole with hot glue gun. Used butt connector on theView attachment 470380View attachment 470380View attachment 470381 other end to attach to stripped wire coming out mirror. Both ends sealed with shrink tube. Total cost of repair, $3.60
AkNoad2
Thought I would add to this thread some info I was able to find. If you need a puddle light connector, the only place I found it was at Connector Experts. They aren’t cheap but it beats the alternative of having to buy a new mirror. The part is CE3368BK, they are pre wired and ready to hook up to your existing puddle light wires, cost $78 plus shipping. I bought 2 along with 2 new lights off of eBay. Didn’t realize how much I missed them until I saw them on my buddies Rebel.
LOFSFIRE
2013 1500 CC Sport Copperhead Pearl & 2011 1500 CC Sport Black
5.7 Hemi w/ 8 speed ~ 5.7 Hemi w/ 6 speed
So I've scrolled through pictures of connectors for hours on mouser.com with no luck and after lots of digging I found this post which led me to find the correct connectors. But because there is no way in hell I was paying $78 for a couple $0.50 connector... I kept digging. Ultimately, I found this part number 12047781.
"Aptiv (Delphi)
12047781 - Delphi Metri-Pack 150 3 Way Black Unsealed Female Connector"
So to help out anybody else that might be looking for this, if you do a Google search for that part number you'll be given many options. Many of which are just the connector. You need to make sure you get the terminals for the inside as well.
Good luck!
GTyankee
3.0 ecodiesel
this is a 2009 - 2017 or 2018 mirror
Look below the motor, in between the 2 arrows at the bottom
you can just barely see the 3 wires that go to the Puddle Lamp
the newer mirrors use a slightly different mirror motor
the mirror glass is more difficult to remove
Meatman8769
Comox, bc
This literally just happened to my 19' ram 1500 classic....led puddle lights went out so I ordered a replacement from mopar online. Came in. When I went to pull the connector out of the old one I found that it was corroded really bad and one of the pins came out and was stuck in there. I cleaned the female end up as best as possible with a q tip and a needle as its a tiny area. Luckily I plugged the new one in and it works but without getting all the corrosion out I'm afraid it'll happen again.
Kusanation
Ontario
I just ordered the female connector from "customConnectorKits" SKU # 12047781. I am waiting for them to come in. Does anyone know if its hard to get the wires in it or how to do it once I get this part? Ive never done it before.
LOFSFIRE
Not hard at all, but did you get the 12064971-L - Delphi Metri-Pack 150 Tin Plated Unsealed Female Terminals?
I think this goes with the part you ordered but I'm not 100% sure. Which is why I order mine above as a full kit. It came with all the parts. I just cut the old connector off. Then striped the wires back and crimped the terminals on. Make sure you put the terminals in the correct slots on the connector. Or you will need a Terminal Removal Tool kit to get it out with out breaking it.
Kusanation
Ontario
No I didn’t get that. How can I purchase the entire full kit? Is there an option for that? I clicked the link you shared and it just provides the terminals. How many of them to do I need to buy ? 3? Thanks for your help on this, it’s been a pain in the ass.
Kinta77
US
Thanks!
no you dont need the whole thing , you just need the conector for it ... you need this giod luck
ACDelco GM Original Equipment... https://www.amazon.com/dp/B00RW3BZ5W?ref=ppx_pop_mob_ap_share
LOFSFIRE
Yes, you do need the full kit or all the parts. The link you have is a complete connector. It also has wires coming out of it already and is double the price.
Sorry, I have been swamped with work and have not had time to check back on here. You may have what you need already but here is what I bought.
Title of the listing incase the like does not work: "Lot of 2 Delphi Metri-Pack 150 Series 3P Connector Kit Unsealed 3 Position NOS"
