Pulled The Trigger on Lighting & RED Mount
OC455
Central NY
I went ahead and purchased a Randy Ellis mount for the front of my 3500 and Morimoto BigBanger pod lights. (NCS) spots/combo.
When the lights come in I will get busy on the install.
OC455
OC455
Central NY
Morimoto BigBanger light pod:
Randy Ellis Design Light Bar Mount:
The Randy Ellis Design Sleekster light bar mount is the only one that I've heard of that doesn't interfere with the front parking sensors.
If anyone is interested, on The Retrofit Source website, they have the Morimoto light pods and light bars on sale for 15% off right now.
that sounds really exciting, but i have no idea what it means
diymirage
Banned
Nice. Very 80s looking, specially with the round lights on thier website
My truck still has the early version of parking sensors (bumpers) so I never considered sensor interference (plus, I plow with mine, so low mounted lights would be pointless on my truck)
OC455
OC455
Central NY
Yeah, would like to have a bit more lighting on some of the back roads I travel on sometimes.
OC455
OC455
Central NY
Just got the Morimoto BigBanger NCS light pods in. Just to give anyone an idea of their size.
MattHemi
That's huge! Looking forward to your installation update
OC455
OC455
Central NY
Got the bar mounted. Kind of a pain in the @$$. The lights aren't fixed and permanent yet. Still have to run the wiring harness. Thinking about adding ditch lights.
OC455
OC455
Central NY
Well, it was my birthday this past weekend. Not really anything to talk about as far as the day was concerned. Of course I got dinner and that was about it.... :/
Anyway, I ordered ditch lights and the brackets for my birthday. And extension harnesses to run them.
The harness has the ability to run seven light pods, and seeing how I have six altogether, it will work. It's interesting the way the Morimoto harness is setup. It has two separate switch capabilities. I can run the center spot light pods on one switch and the two combo lights pods and the ditch light pods on the other.
I bought a plug and play harness for another lighting project I want to do, and their setup uses the DRL lights to trigger the LED light I will be using. I would like to tap into the plug and play harness to tap the parking/running light wire so that the DRL's on the light pods will dim down at night. I do not want to tap the trucks OEM harness.
I plan on using two upfitter switches that are already there for the pods.
Now on to the other issue I am running into. The included hardware for mounting the light pods is a M10-1.5 short carriage bolt with a large button style head that uses an Allen head wrench. It uses a nylock nut and washer to secure the lights. The only problem is the holes that are in the light bar mount are I believe 9/16's or 5/8's of an inch. I went to a couple of hardware stores and eventually went to the local Runnings store and found black nylon bushings that fit the mounting holes in the light bar. The bushings fit perfectly in the holes, the only issue is the M10-1.5 bolts are slightly to big for the 3/8 inch hole through the middle of the nylon bushing and they are a 1/4 inch too long. This coming weekend I will open up the hole through the bushing to fit the provided bolts and then probably sand down the length so it is no thicker than the mounting tab.
I will get some pics of what I'm talking about if anyone is interested.
The only other thing and I asked in a different thread is where can I find a wiring diagram or what pin outs are for the headlight harness so I can find out which wire is for the running/parking light? Pics to follow.
OC455
OC455
Central NY
I"m hoping this is the correct connector/wiring pin out:
Removal Tools​
A specific removal tool has not been identified.
Pin Information​
CavCircuitGaugeColorFunction
1L430.75WH/DBLEFT LOW BEAM DRIVER
2Z9070.75BKGROUND
3L330.75WH/GNLEFT HIGH BEAM DRIVER
4Z9070.75BKGROUND
5L610.75WH/GNLEFT FRONT TURN LAMP DRIVER
6L5510.35BG/BNLEFT FRONT LIGHTING FAULT SENSE
7L770.75WH/BNLEFT FRONT PARK LAMP DRIVER
8L1450.75WH/OGLEFT SIDE MARKER CONTROL
9Z9070.75BKGROUND
10D5030.35WH/OGLIN LIGHTING
11N00NANO CONNECT
12N00NANO CONNECT
13F9270.35PK/YERUN RELAY OUTPUT
14Z9070.75BKGROUND
15D4040.35WH/BNLIN BUS
16L1170.75BG/DBLEFT FRONT PARK LAMP DRIVER
End View​
/connectors/33472-1606.gif
OC455
OC455
Central NY
Ok,
Just doing my due diligence here and decided to check and see what else I would need to get this install done.
Reading the info for the harness for the pod lights, it has a wire for the back light for the pods and says it needs to be an ignition switched fuse. A fuse tap is included for this. Checking the fuse box lay out, it looks like F90/91 IGN/ BATT should be used. (20a fuse).
There is a wire that they recommend using with a T tap into the positive side of the parking light or low beam headlight circuit as an intensity dimmer for the backlight for the pods I planned on using the plug and play harness I have to accomplish this, until I saw that there is a fuse for ID/Clearance Lights F79 (15a fuse). I'm thinking about just getting another fuse tap and use the F79 fuse as the trigger for the intensity dimmer for the backlight feature.
Anyone with more knowledge than me with auto electrical, please let me know if I am on the right track or need to do something different.
Here is a couple of pics for the black nylon bushings I am going to use to mount the pods to the bar with supplied hardware. I think I will just use the bushings from underneath and skip using the washer because the flange on the bushing is rather thick.1000001287.jpg
Just have to get rid of some of the length off the center part that goes through the hole.
I also git the ditch lights and brackets in. Will get them mounted shortly. I did get the heavy duty Diode Dynamics extension harness to run up to the ditch lights. But the actual Deutch connectors (4pin) are too big. Almost oversized and won't work with the Morimoto pod lights or the harness. Have to order the other ones. Hopefully these will be okay.
OC455
OC455
Central NY
Guess I need to find another source instead of F90/91....not a good fuse for.powering the lights. Maybe there is a fuse spot not being used that has power with the ignition.
OC455
OC455
Central NY
After thinking about everything I decided to take the truck and lights and wiring harness to JPJ Communications a local shop that wires up EMS/LE and municipal vehicles with lighting and coms equipment. They did a way better job wiring everything and keeping ti clean and neat under the hood.
The backlight feature works as it should, dims when the park/headlights come on, theyre' run into the factory upfitter switches.
I need to adjust them for the optimal lights output and pattern. I will get some good pictures of everything later....tonight is windy and rainy.1000001420.jpg
OC455
OC455
Central NY
OC455
OC455
Central NY
I adjusted the lights pods tonight. Might need to tweak them a bit to make sure. I went to an old air force ammo bunker area to get them set and then went to a dead end road to see if they are good to go. No worries there was no traffic there at night.
Pod lights only, no headlights or fog lights.
Low beam headlights. No fog lights.
High beam headlights. No fog lights.
Center spot lights only.
All pod lights on, no headlights or fog lights on. I tried the front combo lights and ditch lights on driving on one the back roads in the area and they are amazingly bright. Almost can't tell the high beams were on. Morimoto BigBanger pod lights are awesome.
diymirage
Banned
dang, impressive
when you say "center spots" are those the ones mounted on the hood?
im toying with the idea of putting some amber "snow lights" there on my truck, but im worried it may be too high for snow lights and still get too much reflection of the flakes
OC455
OC455
Central NY
dang, impressive
The center spots are on the light bar in front of the bumper (the two middle lights). The ones on the hood are the ditch lights which are amber combo lights.
If you are thinking about amber lights for snow, look at the 2Banger or 4Banger lights with the wide pattern.
diymirage
Banned
Yeah, im thinking amber for snow, but mounted on the hood latch, like you have your ditch lights (they would need to be high enough to shine over the plow)
I just dont know if thats a good spot for them, because of the way snow reflects light
gville35
