Pulling heavy during break in?
cc rider
Western NY
I know the manual says drive moderately, brief open throttle, blah blah during break in. But, wouldn't pulling heavy weight with under 1000 miles be a little much on the engine and tranny . I'm specifically referring to my 6.4 with probably around 13k at last.
14hemiexpress
6.4l
Go for it! That's plenty I would pull heavy at 1000 miles
C
cc rider
Western NY
But I only have under 200 miles right now. I should be getting my rv within the next week or two. I won't have near 1000 miles. It's bike season. I have 2 bikes. besides I can't afford the gas for the truck :).
MADDOG
Living in a Firepit
The manual says don't do this. You should follow the break-in as stated in your owner's manual.
Upthewazzu
Spokane, WA
1500, Hemi 5.7, 3.21
Take a drive out into the country this weekend and put a few hundred miles on it.
14hemiexpress
6.4l
Sorry miss read, youll be towing 13k. The manual says 300 miles go for a good drive and go pick up the trailer!
loveracing1988
Clarkston, MI
You waited how long and went through all of the hassle to get the truck, don't screw it up now and mess up the break in. Get at least 500 miles on it and then try it. I wouldn't be going directly to towing 13000 pounds but that is just me.
TerraNewf
NL, Canada
I got the 6 banger and I have 1460 kms on it. Still taking it easy and just a couple of paddle to metal runs. Pulls really good, but not a "Hemi"
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Really.....
My manual said drive moderately for 300 miles, with no speeds over 55 for the 1st 60 miles.
It also said no towing of any kind for the 1st 500 miles, and then for the 1st 500 miles of towing, do not exceed 50 mph.
I wouldn't tow that heavy until there is at least 1000 miles on the truck, but that's me.
C
cc rider
Western NY
I see the break in section. I didn't see anywhere where it says to not tow for 500 and to tow at 50 after. Where do you see this. I threw a couple hundred miles on last night. Now I have 350 miles. I don't want to hook up 13 or 14k pounds and put any undesired strain on the truck. Thanks
14hemiexpress
6.4l
Really.....
I must of missed the rest all i saw was drive moderately for the first 300 I could of very easily missed something.
Honestly at 500 you should be solid these engines require very little brake in the tolerances, oils and assmboly methods are so good at 500 miles just get that puppy home and put a few more miles before you pull with wot accleration with the trailer.
TRCM
USN, Retired
Newport News, VA
Page 551 of my manual, under towing, and then towing requirements
Towing Requirements
To promote proper break-in of your new vehicle drivetrain
components the following guidelines are recommended:
CAUTION!
• Do not tow a trailer at all during the first 500 miles
(805 km) the new vehicle is driven. The engine,
axle or other parts could be damaged.
(Continued)
CAUTION! (Continued)
• Then, during the first 500 miles (805 km) that a
trailer is towed, do not drive over 50 mph
(80 km/h) and do not make starts at full throttle.
This helps the engine and other parts of the
vehicle wear in at the heavier loads.
WARNING!
[/I
It's on page 600 of the 2014 manual.......says the same thing too......
C
cc rider
Western NY
my manual is only 296 pages and it says nothing like that in the breakin section or towin section. Ill look into it a little more though
14hemiexpress
6.4l
I think your completely safe if you get to 500 go pick up your trailer get it home slow no WOT slow accleration keep speeds moderate get about 1000 on it before you load it up and give her hell.
TRCM
USN, Retired
Newport News, VA
Well, I went to ram trucks, and downloaded the owners manual for 2015 2500/3500 trucks....and it is 883 pages long vice 296....so I am not sure what you are looking at and calling an owners manual.
And, in the Starting & Operating section of that manual, on page 664, right hand side of the page, it says:
Towing Requirements
CAUTION!
(805 km) the new vehicle is driven. The engine, axle
trailer is towed, do not drive over 50 mph (80 km/h)
and do not make starts at full throttle. This helps
the engine and other parts of the vehicle wear in at
the heavier loads.
Amazingly just like what I posted earlier. :roflsquared:
BTW, it is nice to have it all on the computer too, if you want to download it.
It is free..................
KarL45
Western Slope, Colorado
2018 Ram Express quad cab 4x4
5.7 MDS
I had about 4k on mine before I pulled our 13k 5'er. That said, was fairly well broken in as had a round trip to SD , about 1300 miles plus everyday driving. Still, wouldn't want to pull that heavy under a 1000 miles. Don't know your elevation or diff gearing, but can tell you in the hills and or higher elevations, especially if you have the 3.73's , it will be pulling hard. Also, I personally, would have your first oil change after pulling the first time. My opinion, the first few thousand miles is where you will have the greatest wear on your engine. Just my thoughts.
C
cc rider
Western NY
Is that unloaded weight or all loaded up? I have the 4.10
C
cc rider
Western NY
Now, i got it. I called ram and they will sned you ALL the literature free with a new vehicle purchase. It is the manual you are talking about on paper. Its a monster book! They also send a warranty book and uconnect book. The manual I was talking about came with the truck and goes in that holder that has a spot for business cards and a pen.
Towing Requirements
CAUTION!
the heavier loads.
TRCM
USN, Retired
Newport News, VA
if I was you, I'd download it as well.....much easier searching for stuff that way.
Plus, if it's raining outside, you ain't got to run to the truck to check.
