Pulling out Fence Post
adrianp89
Tampa Bay, FL
Hey guys, I have a metal fence post that is cementer into the ground that I need to remove... can I use the truck's tow hooks to yank it out (with straps of course) ? Or should I play it safe and just dig it out.... trying to save myself from doing extra in this FL sun.
Kenneth1977
2016 Limited 4x4
Just give it all the skinny pedal
More than likely it will just snap off at the bottom
Phylodog
Arcadia, IN
2012 & 2018
5.7 Hemi & 6.7L CTD
I'd buy a Hi-Lift jack and go that route long before taking a chance of the post (or part of it) flying into my truck. If the cement isn't right at the surface and you don't need to put something in its place I'd dig below grade, cut the post off and leave the cement there.
NewBlackDak
6.7L Cummins
I've pulled plenty of posts and stumps, but I normally use a hitch d-ring:shackle. No idea what the tow hooks are rated for.
WilliamS
Tampa FL
The tow hooks will pull it, the problem is where does the pole go when it breaks free?
DannyMK2
Long Island, NY
2015 Power Wagon
its easier to dig it out by hand. chances are using the truck is just going to bend the pole, rather then take it out all the way. once you dig around, give the pole a few wacks with a sledge hammer. it usually breaks the concrete free around the pole and you can wiggle it out.
Farmer Fran
Earth
2025 Limited Longhorn
SST H.O.
I dig then pull the weight up with the truck.
Wise
Harrison, Ohio
I've used and old wheel to pull them worked out great especially if they are cemented in
Wise
Harrison, Ohio
A general idea I've just wrapped the chain at the bottom, never had a problem with it slidding up. It'll pull the post up instead of from the side just put a rock in front of it.
Devin1349
how deep is the cement???
A
adrianp89
Tampa Bay, FL
No idea on depth - I assumed put the truck in 4Hi and pull slowly so it doesn't fly at me lol.
Ratket
Arizona-
Use 4low and let it walk- slow is the key- if u have to jerk it dont- That's when u get into " flying debris" territory
UnsatFC
Active duty NAVY
New Jersey
I agree, 4low and walk....unless you want a new tailgate or rear window....I have seen neighbors do exactly that.
Skubasteve!
Fantastic idea.
14hemiexpress
6.4l
4lo and rock it nice and slow. Personally I used engine hoist to pull my old fence post but if you can get the truck in there you may as well try if you don't have a high lift or engine hoist. Just but smart use a strap or if you have chain put heavy blanket on it so it it snaps it doesn't go flying. Don't use a hitch ball. Feed a strap into the receiver and slide the hitch pin in there to hold it, much safer. Personally I wouldn't use the tow hooks only because that means your trying to pull it in reverse and I have herd stories of that not being good on your truck something to with being bad on your reverse gear, I'm not sure how much of them are true. Just my .02
Ratket
Arizona-
^^^ It's not the gear it's the "Half shafts/Axels"
You're truck will pull it right out- no way a "Fence post" Sheers one of those front tow hooks. Remember just 4 low and slow-
Let us know how she goes
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Personally, id not use a front tow hook. I'd use a strap on the rear hitch and pull with that. The receiver is made for pulling.
Those front tow hooks can pull, but your asking a lot of them and i could see them bending or tearing the frame if you put enough stress on them. Just my .02 good luck
A
adrianp89
Tampa Bay, FL
Thanks for the advice guys, I will let you know what I end up doing and how it works! Probably won't be for another week or so.... waiting for my chainsaw to come in... have to cut down a few things first.
