pulling right when I brake...
LilRamMan
Haslet Texas
Ok so I just replaced the front brake pads and my right rotor and now it pulls right when I hit tye brake. Any ideas?
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Did you grease the slide pins?
Did you break down the callipers and inspect them for binding?
Callipers are really cheap to rebuild like $10 to $15 bucks a piece.
LilRamMan
LilRamMan
Haslet Texas
Yes I did grease the pin. Did not inspect the caliper... I'll check that tomorrow thanks.
quietpeen
2021 TRX
Hellcat
when it pulls to one side doesn't it usually mean the opposite side is not braking as hard?
txbass06
NE Texas
5.9 Magnum
Yep. If its pulling to the left, I'd start with the right
LilRamMan
LilRamMan
Haslet Texas
So if one side is braking too hard, how exactly would I go about fixing that?
ArmRippinToys
Anchorage, AK
If you put new pads and only replaced
The right rotor that could be your problem your tolerances between pad and rotor will be tighter on right than left, suppose to do both sides at the same time at least, and the best way is do all four corners at the same time
