Pushrod question from a newb
Billybob3358
I have an 04 hemi and am doing the 6.1 valve spring swap I am also replacing pushrods I have read that 6.1 pushrods will work with stock cam and I have read that no they will not work with stock cam my question is will they work or do I need to go with the 5.7 pushrods thanks Ryan
charonblk07
Calgary, Ab
F1-A forged 349ci
Spring install height needs to be the same with 6.1L springs, so stick with stock 5.7L pushrods. Only reason to change would be if you were running a larger cam or a regrind that would need longer rods.
gville35
