Quad headlight question
maple
San Bernardino CA
I pick up spare set of quad headlights tonight off of CL, I'm trying to plan out my build, I want to stick a 2by3 led cube where the high beam goes. My question is can I just connect the led cube to my high beams instead of the Standard bulb? If so how should I go about doing this.
I have a 2015 and don't want to run into any problems or get any light out message on my dash.
Rzrman328
The treeline
I've seen this done on a few Rams. I have 4 LED lights running off my parking lamps with no errors. Not quite the same but still.
I don't see a problem with them working but not sure if you'll get errors or not. 15's are horrible for lighting upgrades.
1500ram12
5.9L Cummins
You most likely will run into problems. As stated the 15's suck for swapping anything other than halogen bulbs in for lighting.
M
maple
San Bernardino CA
I think I'm gonna run a full hid with bi projector on top and have a relay run the led cubes
capebreton1967
