Quadzilla Programer
ramhunter9
P-Star Jeep Wrangler
Anyone know much about this unit . My truck has one , still learning the thing . Found the paper work on it . This was a 700 dollar freakin tuner ? 165hp is says for the truck . Kinda cool gauge pod deal . I can monitor exhaust temp at the manifold , oil , trans , coolant , ect .. My question is do many people run these ?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I have seen one in a dirtymax, mostly seen the dodges running Edge and Smarty.
ramhunter9
ramhunter9
I got the PV2 controller coming that way I have 16 items on screen I can monitor . I will mostly just be monitoring the EGT , boost , trans , oil , and fuel pres most of the time
The one in the truck now is one you have to scroll threw .. I want them all on one screen
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
How big is your programer? Is it the large hand held or is it small enought to be mounted in a piller pod?
ramhunter9
ramhunter9
I have the pv2 and a mount I installed by the radio. I will text you a pic.
RubberFrog
Text a pic? That's some rooky **** right there. Put it up here for us all to see!
I have heard only good things about the quadzilla.
txbass06
NE Texas
5.9 Magnum
I've got a buddy that just bought an '02 cummins with the same programmer and he loves it. Haven't heard anything bad about them at all
- Sent from my iPhone 4 using Tapatalk
JP03
New Jersey
Cummins 5.9
i have the edge with attitude and all u do is play with the up and down buttons for pre loaded settings
ramhunter9
ramhunter9
How do you like it ? O love mine so far. The ability to adjust tunes on the fly is awesome. I run mine on 7 or 8 most of the time. 10 is WOW
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
I'm setup a bit different than you...
Edge Comp and Seperate Gauges
I run my Edge Comp wide open on 5x5 for maximum timing curve this is more for the MPG nuber than HP/TQ numbers.
As for my Gauges...
attachment.php
Then I also run a ScanGauge II...
attachment.php
ramhunter9
ramhunter9
I want a scan gauge sooo bad
Can you use that as a code reader also ?
ramhunter9
ramhunter9
Bad ass ... how do these hook up .. OBD ?
Mopar1973Man
New Meadows, Idaho
ramhunter9
ramhunter9
What is the cheapest price you seen on them ?
Can they read codes also ?
ramhunter9
ramhunter9
Bitchen ,,, my next mod for sure
falcodave
CTD
I'm having problems with my Xzillaraider II module on hot days. If the truck has been sitting in the sun on days when the temperature is above 105 degrees, then the Xzillaraider module will not power up. The ControlPOD shows dashes all the way across.
If I start the engine it goes into a very heavy surging idle. If I touch the accelerator pedal, it immediately goes to wide open throttle until I turn off the ignition key.
As stated in the directions and the warning sticker on the Xzillaraider module itself, I installed it in the cab of the truck directly underneath the steering column. In fact this is where I installed the 1st generation Xzillaraider module that I am trying to replace.
Once the Xzillaraider cools down it works just fine. I have been in contact with Quadzilla (Jeremy in support) and even returned the module for a checkup. Quadzilla returned the module with me stating "Module checks out and is working fine. I can recommend to customer is that he unplugs the module instead of leaving it in the truck." That is certainly not the response that I was looking for.
Upon calling Quadzilla to express my concern at this response, Jeremy told me that he had replaced the board before shipping it back to me. When I compared the current board to pictures of my "old" board, the silk screen looks to be identical, including areas where there are voids.
Now that the weather seems to have broken in Phoenix, I'm not sure that the problem will happen again until next summer.
I must admit that this is my 2nd purchase of Quadzilla products and my experience with Quadzilla has been good till now. But I am not getting the old warm and fuzzies at the moment. I have never heard of any other manufacturer recommending that their product be unplugged instead of leaving it in the vehicle when parked.
Jantelaw
