Rupert
- Feb 11, 2016
- 285
- 90
- Location
- Annapolis, Md
- 2014 big horn
- Hemi 5.7
IF you are using a "canned tune" and of course if you swap out your PCM than you shouldn't have a problem remarrying your tuner after an update from the dealership . The Diablo tune writes to the new factory backup, just like it did the first time you married them.
Remember when you first hooked your tuner to your truck and it needed a CALID update and then you were running back and forth from the truck to your laptop? Its pretty much the same thing.
If you run a custom tune and put your truck back to stock, you will need to send your CMR tuner your new factory backup. As I recall the last letter of the CALID changes, E.G. AF becomes AG. Therefore the CMR tune will not match your Factory tune and NO you cannot just change your filename.
The importance of the factory updates has ben discussed above I' ll just add that you can find out what the updates are via the web and see if you want to go to the trouble. As time goes on there are less and less updates, as you would expect.
I try to never go to the dealer for anything other than select parts.
Something else to consider are recalls and configuration changes: want to add a brake controller....you should put it back to stock, etc.
recalls....My 08 charger needs the clockspring thing, the airbags and the key done. I got rear ended last fall and now I need the gas tank replaced as if I top it off the car stumbles stalls and pukes for the next 20 miles, which Dodge MAY cover, but I cant take my car in there cause It is heavily modified and wont run on the factory tune.
I can probably use the one mod friendly dealer ship I know, and maybe get them all done in one day......but that will take a lot of effort.
SO if you are going to go with a cam, long tunes, FI etc. that is something to consider
