Question for those who know 4X4 best
Mineralram
Last weekend I cross rotated my tries in my garage. The garage is on a slight incline because of my driveway being on a incline also. I put my truck in 4X4 low, in park and with emergency brake on. When I had the front end of the ground I was able to spin both wheel by hand. Is this normal on the new auto 4x4 systems
Mineralram
Mineralram
yes
Sent from my SM-G930W8 using Tapatalk
cbsmith
New Brunswick, Canada
2014 Ram 1500 Outdoorsman
With 4x4 auto this is normal. The system
Uses and electrically engaged clutch to power the front wheels, so when the truck is off the clutch does not have power.
6.7CumminsDrvr
The Dude abides………
Georgia
For the "auto" BW-44-44, the Tcase won't lock up unless the rear wheels "slip" at which point the clutches "lock" (and I use that term lightly) and power is then going to the front. Since you were in park, what you experienced would be expected. No worries man!
Hemi395
Cape Cod MA
In that case you have the Borgwarner 44-44 transfer case which doesn't lock until the rear wheels slip. And even then it's through a clutch. Then as soon as you let off the throttle the clutch disengages. Stupid design but all the higher end 1500s come with it.
Mineralram
Mineralram
Thank you for the detailed explanations they certainly answered what I was looking for.
