05ram4x4
- Aug 28, 2012
- 596
- 34
- 2002 Ram 2500 4x4 Quad cab
- 5.9 Magnum
I was replacing my cv joint and I removed the upper ball joint from the knuckle. I noticed that when putting it back together the hole in the ball joint (for the pin) seems too low. So when I tighten down the nut the pin barely sits in any of the grooves in the nut. If I loosen the nut down a bit so the pin can actually lock it in, the ball joint has room to move up and down. Is that normal? I hope that makes sense. If Not I may be able to get a picture or something. Thanks for any help or information!
