Questions about ZF 8 transmission fluid change
Garth Schindel
Didsbury
Hi
I've read and watched lots but I still have a couple of questions.
Do I drain the fluid when its cool or when its between the 30-50C (86-122F)? One video https://www.youtube.com/watch?v=kXK...Ds9wMi6TZg&start_radio=1&rv=kXKhZievmSI&t=924
said to drain it when its below operating temp but I thought I also read to heat it up first. Wouldn't you get more out if its warm? Once comment in the video said to drain and then run the engine to get the oil out of the cooler - this sort of sounds reasonable - has anyone tried this?
This video https://www.youtube.com/watch?v=BPkCUfqi-gE talks about how to make sure you have the tranny full to do the regular fill procedure then drive the vehicle until its hot, let it cool and then do the fill check procedure again. This is to make sure the tranny cooler was full too. Needed?
The last thing I'm questioning is how to do the rev to 2000 - is this in park or neutral? Does it matter?
Thanks for the help.
MRFREEZE57
pacific northwest
If I remember correct I ran mine up to temp then let it drain for about 1 hour, then make sure you raise the rear end up to get the tranny level before refilling.
G
Garth Schindel
Didsbury
I had planned on warming it up before draining but the one video specifically said to drain it cooler than operating temp. He seemed to know what he was talking about. Would doing this keep the fluid out of the cooler so more drains out?
PaleFlyer
Charlotte NC
Warm it up some so it flows better, but not to warm, or it's too hot to work with.
As far as drain off what you can, then run the engine... I'm not a mechanic, but I would NEVER do that personally.
G
Garth Schindel
Didsbury
Thanks. Warm enough to flow makes sense. Keeping it below the temp where it gets into the cooler can’t hurt.
No I won’t run it with the pan off. Even FZ says not to do that that in big bold letters.
After a pan change, Do you believe in changing just the fluid a couple of times to get make it more pure? / less old stuff.
MRFREEZE57
pacific northwest
I drained my fluid 3 times total, about 200 miles apart to get a good flush, used Redline D6 but many have said had good results with Valvoline Maxlife.
My advise, go with a PPE pan for replacement, the drain is much easier accessible and not right under the exhaust cross over and it has a replaceable filter. They run about $275 but are well worth the extra cost.
