Quick question about diablo trinity T-1000
Sladerade
North Carolina
When you do a gear swap from 3.55 to 4.56 do you need to retune for the 4.56 if you have one if the canned tunes installed?
Wait a second... I'm posting from an iPhone?
BlackRamHemi
Edmonton Alberta Canada
No need for tuner adjustments after a gear swap, only tire size change.
(speed sensor is in the ABS tone ring where 1 revolution still equals 1 revolution regardless of ring/pinion ratio)
Sladerade
Sladerade
North Carolina
Awesome, thank you BlackEamHemi! I wanted to make sure that I would not have to flash back to stock and then reflash. I already have the tires set to 35's
Two Dog
Ontario, Canada
2014 RAM RCSB Express
When changing tires sizes with the tuner, I'm guessing you have to measure the true diameter of the tires with the vehicle weight on them first?
BlackRamHemi
Not really, best bet is to enter the metric tire sizes,
For me it's 305 for width, 50 series, then wheel diameter 20".
Then to confirm test drive it and check against a hand held GPS or highway mile markers for accuracy.
Diameter doesn't really factor in, mounted with weight on it or sitting in the air the circumference shouldn't change.
its the distance traveled per rotation that matters (aka revolutions per mile)
